Mugabetown - Whoretownin' At It's Worst.
post is useless without pix bro
x2
If he is throwing scissors at you I am putting a 3.2l stroker in mine to fix that problem
lol, I dont want to say anything i may be forced to eat later so im going to say there is a "Chance" Nick will throw scissors at me. Even if it is a pair from his school pencil case
Nice little surprise
