Mugabetown - Whoretownin' At It's Worst.
plugs? As in new plugs or plug cleaning kit
no Air filter cleaning kit and new plugs
Sooo, remember the post from yesterday where some ebay seller used a picture of my car to sell their copy of the drag wing.... I emailed him giving the car a wrap and asked if its his. To which i got a reply stating he is the proud owner of said vehicle
should of brought something and arranged local pickup and rocked up in the car asking where his was.
Now this would be funny. I dont mind that he used to car to sell his product [event though i didnt buy the product off him] I'm just surprised he said its his car
bad uncle Natro very bad uncle.....
Was going threw my engine parts yesterday and there's a bunch of pushrods rubber banded together, made me giggle cause well you all dislike them lol
u know us sooooooo very well.
I will check out your build thread in a minute man and see what evil plans u have ahead lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
