Mugabetown - Whoretownin' At It's Worst.
Morning all, back at work this morning for another day.
Cowdy - As Nick said just ignore him. He wont be the first person or the last that trys to hand shit on you for owning a Skyline. There is a fair few haters going around.
Morning all!
Cowdy, we all know that 34s are shit. 35s are where it's at. ;)
Also, charity cruise!! (Needs to be mentioned on every page).
Also, noticed that I have a few PMs. Didn't even realise! So if you've PMd me, I'll try and get back to you today.
Morning all!
PM's are priority Tony!!! Might just shoot you one for the lulz really..
Whats everyones plans for today. Im hopeing Richard @ All Star will give me a call today with some good news...
I'm usually good at getting back to them. I don't get notifications on my phone so only noticed by chance!
I've noticed if you dont check your emails regularly and get notification that way then its hard to know you have them. specially if using the mobile theme
I use Tapatalk, and it's been great just not with notifications for PM. Actually, just checked settings and notifications were off.
With emails, I'm quite diligent with them as it's my work email address. Long weekend. Shit happens.
is taptalk the paid app thing? whats your thoughts, worth getting?
I mainly use my ipad for SAU and use the ful site on it
I just use tapatalk on my phone and it's pretty good. Haven't got any issues. :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
