Mugabetown - Whoretownin' At It's Worst.
Gooood morning folks. you know what day it is today? Home day!
V35's don't have a rear wiper. Cause inferior model of skylines etc. :rolleyes:
Does your work have any policies regarding Fatigue etc, particularly with driving?
Not familiar with V35s, that would explain it.
WHS Policy would be a great example :)
Have you seen my brakes? :P
One thing that I don't understand is, you've done so much to yours and it's pulling 285rwkw. Why are the z32 guys then saying that it's easy to pull 300 rwkw from a VG30?
I refer to this: http://www.skylinesaustralia.com/forums/topic/432767-300zx-tt-potential/
It can be done easy enough. I have a stock 24year old bottom end so I am only running 17psi. Turbos are good for another 4/5 psi. And they are just the little 2560's ;)
Edited by MagicMikeZ32
Morning Ants. How goes the new additions? Both car and kid?
its good mate. So pleased to have them all at home.
Back at work today, so can't play much with GTR nor spend time with my little one :(
But need money and so does my boss which is totally understandable.
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
