Mugabetown - Whoretownin' At It's Worst.
Gooood morning folks. you know what day it is today? Home day!
V35's don't have a rear wiper. Cause inferior model of skylines etc. :rolleyes:
Does your work have any policies regarding Fatigue etc, particularly with driving?
Not familiar with V35s, that would explain it.
WHS Policy would be a great example :)
Have you seen my brakes? :P
One thing that I don't understand is, you've done so much to yours and it's pulling 285rwkw. Why are the z32 guys then saying that it's easy to pull 300 rwkw from a VG30?
I refer to this: http://www.skylinesaustralia.com/forums/topic/432767-300zx-tt-potential/
It can be done easy enough. I have a stock 24year old bottom end so I am only running 17psi. Turbos are good for another 4/5 psi. And they are just the little 2560's ;)
Edited by MagicMikeZ32
Morning Ants. How goes the new additions? Both car and kid?
its good mate. So pleased to have them all at home.
Back at work today, so can't play much with GTR nor spend time with my little one :(
But need money and so does my boss which is totally understandable.
