Mugabetown - Whoretownin' At It's Worst.
Ok I'm back I missed her :(
How could you miss her? You never met her! Are you like one of those teenage kids who goes on two dates and beleives that the girl is the love of his life? Seriously dude! Man up! You're making us look bad!
Wow, I am really being an asshole today. :/
ok northsiders. WTF is the appeal with the northside. everyone is old and quiet and at paddington, rich and boring. i cannot see anything interesting in the local shops and the northside shopping centres are holes full of bogans (Germside Shopping Centre).
when the lease is up i think i am moving to northern NSW to party like it is 1999 for eternity. or at least until i have a stroke or heart attack.
"Likes This"
Whoops wrong site
What I meant, professor smart ass, is that I went to the whore town and she wasn't there ie I missed her not I miss her...
ask Clint. The man knows
Great for rim's. Unless it is a pro job it looks like total Ass on avehicle. What application are you looking to use it for?
x2
Bad job was bad
Over rated shit that looks cheap and nasty, saw a soarer done in it.... Looked bad and he should feel bas
Non pro job was non pro.
Bottom line is after much research it is not worth the effort, Go See Rush he does the hell mad wrapping.
Don't do it is the simple answer, if this advice is ignored please let us know when it is done so we can point and laugh as unless they are an exp spray painter it is going to look incredibad.
What are your plans for tonight?
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
