Mugabetown - Whoretownin' At It's Worst.
What's the plans for the day
might do some restoration work on the GTR........if I find the time.
Will do mandatory groceries, pick up daughter no.1 and then whatever is next I guess
so wastegate spring 1.7, no boost control gives 2bar? Boost creep?
preload adjustment nearly maxed out from previous owner running ~34psi on e85 through their turbo.
i wasnt sure if i needed to back it off or not, but quite obviously i do and have done that this morning. will give it a test this afternoon and see what it does with about 3mm worth of preload instead of all the preload (backed it off a good 5mm or so.)
    • Infiniti US are teasing a manual Q50 as a way to refresh a (very old) model. https://torquecafe.com/manual-performance-sedans-arent-dead-yet/ Can't be too technically difficult given the Z has the same motor with a manual gearbox......here's hoping there is a JDM version we can import here, that would save me a world of headaches
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
