Mugabetown - Whoretownin' At It's Worst.
I'm alright man, just crawling around under a bench looking for a pot I can't find lol.
Also discovered if you drop a raw egg into protien powder and water and whip it it makes it thick and bubbly and awesome...
Mangs exciting times ahead. Put an offer in for a house this morning. Let the games begin. Agent is a massive douche so having fun lowballing him like a mofo lol
so, the angel won out with the house vs car decision
excellent news!! hope that it goes well
good times indeed. Hope it goes in your favour including the right price.
anyone know a good smash repairer?
An Armaguard truck decided to use my 7 series as a bump stop yesterday and i needs to get it going again.
you really dont have much luck of late Benno?
not sure on any good smash repair guys around you mate.
Hopefully some other guys can point you into a good direction
We've got about 900k over the 2 houses :(
im not even gonna go there Mike.........its all too depressing to think of FTM (we went and purchased our house at the wrong time and are paying a stupid amount for it when I know all too well its not even worth that much).
was kinda pushed into it though........but hopefully in time it will be all worth it.
you are the second person to say that to me now. I am feeling lucky though. i have some health and manage to still have some fun so i consider myself quite lucky. so many have it worse.
