Mugabetown - Whoretownin' At It's Worst.
I'm alright man, just crawling around under a bench looking for a pot I can't find lol.
Also discovered if you drop a raw egg into protien powder and water and whip it it makes it thick and bubbly and awesome...
Mangs exciting times ahead. Put an offer in for a house this morning. Let the games begin. Agent is a massive douche so having fun lowballing him like a mofo lol
so, the angel won out with the house vs car decision
excellent news!! hope that it goes well
good times indeed. Hope it goes in your favour including the right price.
anyone know a good smash repairer?
An Armaguard truck decided to use my 7 series as a bump stop yesterday and i needs to get it going again.
you really dont have much luck of late Benno?
not sure on any good smash repair guys around you mate.
Hopefully some other guys can point you into a good direction
We've got about 900k over the 2 houses :(
im not even gonna go there Mike.........its all too depressing to think of FTM (we went and purchased our house at the wrong time and are paying a stupid amount for it when I know all too well its not even worth that much).
was kinda pushed into it though........but hopefully in time it will be all worth it.
you are the second person to say that to me now. I am feeling lucky though. i have some health and manage to still have some fun so i consider myself quite lucky. so many have it worse.
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
    • Well, I was using ECUTalk software if that helps? Not sure if that only can see engine codes? Is there any other software I could give a try? Or any way I can get a blink code?
    • I never touched it, it should have. I'll try to give it an adjust. With IACV plugged in, it idles at around 1120RPM on average. Max 1200 RPM, Minimum 1025RPM before it starts dropping right before stalling. Took the data from the Nistune logs.
    • Thats what im trying to solve bro  no one with aem tuner experience would advice  much appreciate
