Mugabetown - Whoretownin' At It's Worst.
All bolts were out. I thought the hex heads in the center near the plug holes were head bolts.... Look exactly the same, one was slipping g and rounding so drilled it out. Went through.... Was like the fcku and tried lifting it. There ya go
Yeah im not too fussed about it. Theyve had some offers lower than us. Its been on the market for ages. But for 50k more than what its up for now. Its been up for a month now at this price and i dont think it will last at this price but at the same time we're the only ones with an offer in at the moment so he might just sign it and not give a f**k.
We're digging our heels in at this price and he can either sign it or wait for another buyer.
There's a lot of other tax incentives/decentives to think of aswell. If you rent then live in a house, you're up for pro-rata capital gains from the time you weren't living in it, and i'm not sure how room mates work either. Way way simplier if they just pay cash of course. "what room mates? me and my missus were just living alone in this 5 bedroom house?"
And i've quoted the wrong post of yours.
400kw lag city. Similar to -10s i think
Borg warner twins are a muhc better way to go for that sort of setup, supposedly. Or a similar power single is better, or a similar sized precision is better. or something.
not entirely accurate. Should u purchase a primary place of residence and rent it out you will not be subject to any CGT should you elect that property to be your main residence.
Please seek advice from a tax professional should you do this as there are factors that may also assist in retaining the main residence exemption
Yeah we're both pretty up on how all the incentives and systems work. Both in the industry. Good portion of my degree was based around property development.
Main thing is we're happy with the price and the rental returns are great + its in a good growth area blah blah blah.
I just want to have something signed and agreed lol.
I just want to have something signed and agreed for a price I'm content with lol.
FYP
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
