Mugabetown - Whoretownin' At It's Worst.
Stupid pronouncements - but its really simple...............................if all we all behave mate. it should not be a problem.
did you read them properly?
you have to be caught drink driving 4 times before they take your car for good, conversely if your car is found to be too loud, or you accelerated too quickly according to the officers discretion (even if you didnt exceed the speed limit) 2 times thats it, cars gone.
they are saying that people that drink and drive are less dangerous than a car with an exhaust thats too loud.
the bikie laws, thats guilt just by knowing someone, you do not have to have done anything wrong. they then massively ramped up the penalties for anything considered a group, you can get hit with and additional 15 years in prison for any injury to someone that causes as little as a scrape thats broken skin.
* you have to be caught drink driving 4 times before they take your car for good, conversely if your car is found to be too loud, or you accelerated too quickly according to the officers discretion (even if you didnt exceed the speed limit) 2 times thats it, cars gone.
2. the bikie laws, thats guilt just by knowing someone, you do not have to have done anything wrong. they then massively ramped up the penalties for anything considered a group, you can get hit with and additional 15 years in prison for any injury to someone that causes as little as a scrape thats broken skin.
yes mate I did read them properly and fully aware of it.
Do you honestly think that the new bikies legislation will be effective in a court of law?............... I very much doubt it.
The hoon laws have been here in Qld for some time now and are just reinforcing it! I've been subject to it before and I've learned my mistake.
Just about been sensible on the road. I will probably be the first one to get defected now I said that but I will fight for what I think is fair.
There are more unsafe shit boxes on the road theses days compared to say my GTR.
dear god help me then :P
Hahah Emelie and I will enjoy our cake!
hahaha dont start that sugar high thing again. already had that argument in wasteland
I missed that one... Must have had too much sugar...
The noise and smoke offence in QLD is tied to burnouts squaling tyres and what not. Ie it is about the driver undertaking some sort of action that makes noise over and above the noise of the exhaust. A loud exhaust falls under non compliance with the vehicle and safety standards.
Either way its still pretty f**ked up. Go LNP.
Yeah QLD can phase out rego stickers like the other states however can't figure out daylight savings...
im all for phasing out rego stickers.
I do want daylight savings but not in summer
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
