Mugabetown - Whoretownin' At It's Worst.
EXACTLY!!
How falling apart does a car need to be before it gets taken off the road, or even just looked at?!
We respect our cars and keep them in as mint condition as we can, but it's a danger to everyone cause it makes a bit of noise. -_-
And like I get the need for the hoon laws but come on!?
I got defected for my front plate being over to the right a bit....come on!!
I literally can not put the plate in the centre! Be happy there even is a plate haha.
yes mate I did read them properly and fully aware of it.
Do you honestly think that the new bikies legislation will be effective in a court of law?............... I very much doubt it.
The hoon laws have been here in Qld for some time now and are just reinforcing it! I've been subject to it before and I've learned my mistake.
Just about been sensible on the road. I will probably be the first one to get defected now I said that but I will fight for what I think is fair.
There are more unsafe shit boxes on the road theses days compared to say my GTR.
What was in the box is making me go to be now after just fitting it. Test it out. Controle modual frys it's self so I just sent a message back to the place with pics and hopefully they can either send a new one or get it fixed. Also put all my boot linings back In :P
So many zip ties soldering electrical tape and seats out
u still not really said wots in the box dude
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
