Mugabetown - Whoretownin' At It's Worst.
EXACTLY!!
How falling apart does a car need to be before it gets taken off the road, or even just looked at?!
We respect our cars and keep them in as mint condition as we can, but it's a danger to everyone cause it makes a bit of noise. -_-
And like I get the need for the hoon laws but come on!?
I got defected for my front plate being over to the right a bit....come on!!
I literally can not put the plate in the centre! Be happy there even is a plate haha.
yes mate I did read them properly and fully aware of it.
Do you honestly think that the new bikies legislation will be effective in a court of law?............... I very much doubt it.
The hoon laws have been here in Qld for some time now and are just reinforcing it! I've been subject to it before and I've learned my mistake.
Just about been sensible on the road. I will probably be the first one to get defected now I said that but I will fight for what I think is fair.
There are more unsafe shit boxes on the road theses days compared to say my GTR.
What was in the box is making me go to be now after just fitting it. Test it out. Controle modual frys it's self so I just sent a message back to the place with pics and hopefully they can either send a new one or get it fixed. Also put all my boot linings back In :P
So many zip ties soldering electrical tape and seats out
u still not really said wots in the box dude
