Mugabetown - Whoretownin' At It's Worst.
Ahhhhh the stealth approach, very sensible. I still haven't managed to come around to this approach - I actually enjoy arguing the police powers and road traffic act with the 50 :)
Life's more fun with a loud exhaust.
Worry about that when the time comes, the likely hood she'll keep it and do the swap is low (sorry kat but the odds are against you keeping it)
It takes a very very strong bond with a particular car to want to drop money on it when you know there is a cheaper route
It looked pretty clean in the photo Nick, if the car is straight it's worth keeping and just getting engineered. The shells are the same, it's really only the numbers that aren't.
Mine has a dint where the rear right hand pod goes, other than that it's straight. Seriously want over fenders thinking more and more how cool they look lol
Michael that is seriously worrying lol I now rank that in the same category as the gold shorts package I saw yesterday lol
Mostly because she loves taking it hard but she also has some problems...like rust.
Tunnels/mountain cuts especially :D
Got told my car didn't sound like a commodore yesterday, I guess that's a good thing
Tunnels...clutch in...rev-limiter...
It's still a commodore at heart.
You sure? I'd be checking that...
I assumed P platers can tow trailers, I'd check that as well.
You should be able to drive it to the nearest place for the purposes of obtaining registration.
This is correct, just organise CTP first then you can drive it to get a RWC then to the nearest Main Roads dpt.
    • Thanks, I'll shim that plug and hopefully it fixes it.  Yes still factory turbo for now, still have the misfire it's not as bad but still noticeable
    • I had someone check the CU, they said it was fine but it could be buggered  I was only running around 7-10 PSI on the dual stage controller, but my boost gauge is shit house and needs replacing so I'm not getting a true reading.  Then I ran from wastegate pressure as per Turbosmart but still have the same sort of issue
    • Yeah this is a thing. I've had mine setup like this for a few years now, works fine. If I dredge my memory bank, I think I had to do this after I removed my factory dash.  So you've tried it on gate pressure, I'm assuming this is the factory turbo? Did you still have misfire issues with that setup?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
