Mugabetown - Whoretownin' At It's Worst.
real keen to see the ant eater on the weekend :) are you totally in love with it? driven it much?
not too much.....think I did about a 100km since I got it back...........but yes it's great to finally have it.
Need to learn how to drive it all over again..........but jut feels fantastic Bodo :)
good to hear man, guess you'll be takin it easy at the laps of happyness?
well I'm not gonna ring it's neck that's for sure.
Will be taking it sensibly until I get my confidence back up................which is gonna take quiet some time
But I will get there in the end ;)
north side. just watching Scotts build, and hearing that Dan is building Matt's new engine
morning scott hows the car?
Still at All Star Tuning. Long story short is there is a few hiccups here and there with the transplant. Nothing major just little things here and there that need modifying as they foul on other parts etc. Heaps of little niggly things like that.
Last i heard was the E85 was eating away at hte fuel line a little so once thats fixed its ready to Dyno. Its full of water and oil and just needs the leaky line fixed.
I'm just throwing it out there, Colin, Beezlebub89, is a f**king legend! :D
Gidday Tony ma man.
Mine either!
Mine is... Now I am the odd one out...
Changing my pic won't help that tho...
Hello Mell :action-smiley-069:
Did I warn you of the little bits and pieces that just need a little work like I did zac? Having done it they are a dint as it's all little bits and pieces, none of which are particularly difficult to fix but take time and sometimes thing have to be taken back off to sort them.
There is a reason the evo is only going 2.3L and not the different block 2.4 route.
I always knew it was never going to be a simple change over. Im not worried/fazed at all that its taking a few weeks longer with these little things. Id rather it all be done right the first time.
  • Like 1
Hosting the biggest Amateur event in QLD at the moment and all these good young golfers think they are Tiger Wood or Adam Scott.. Hurts my head
Tell them their swing is awful Scottie and that they need to put more hip into it...........................for the lulz :P
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
