Mugabetown - Whoretownin' At It's Worst.
We make a lot of significant' stuff for mining projects (and import a fair share more of it too, to be fair), its just that that isn't a sustainable manufacturing industry.
im sorry do you want us not too post so u can follow???
If you would be so kind :yucky:
Sorry if i rubbed you up the wrong way there, but it twas a busy day in here yesterday
Deemed too expensive.
Ideas on a 30/25 n/a?
Been done with the better rb26 head, forged hi comp with itbs went 170~rwkw.... 10g for 170rwkw is farken dumb.
Then again look at what I built, if you want it do it
I WANs gonna just pretty much set it all up as the 30/25 then when off my p,a drop the turbo on and such
Nick's right. The machining costs alone are astronomical. It has been done time and time again and the results quite frankly sucked.
You can't have turbo compression on an n/a built motor either, the thing would be a pig.
Just don't do it, NA's need hi comp to make power, more compression = bigger explosion = more skids.
My new motor will be built to the highest comp I can go and still run 98 octane
I wasn't gonna do it just wanted opinions and now I know the past failures of people I won't do it haha il just get everything ready for when I get off my p's and yeah
For the least headaches, source an RB25t and start by getting it cleaned and machined. These motors can make big power and cheaply, as many want to do an RB26.
Interested in a billet rotor, Teflon coated, Teflon sealing strips, magnesium 14/71 Mooneyham blower??
They weren't failures, they performed exactly as is to be expected form a natro 3L. Don't get me wrong 170rwkw is farken impressive for what it is, but not for how much it cost especially with no option of progressing.
Like I know I'm not making big power but the potential is there, whereas with this thing.... Well, ur at it's upper limit, u can't put nitrous on it cause it'll ping it's head off and you can't turbo it for the same reasons/u wanted an NA.
Just bad, bad bad bad.....
14/71 dear god he wants all the supermacharger lol. And nah man, Natro power all the way to me, it's more satisfying to make 400rwkw natro than 500 with a supercharger/turbo (yes I'm an idiot) :thumbsup:
You make a lot more than that with this one. I had for a pro street 500ci
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
