Mugabetown - Whoretownin' At It's Worst.
I would be looking for 400+ if that's at all possible with a dirty 30
Stupid comment of the day goes to... Matt!
You don't need big horsepower. Learn to f**king steer. McFly has 260rwkw, Z32 mike had just shy of 300 rwkw, Cadmoon has 180rwkw, Benno's S13 was running a stock RB20 with factory gear and they would all run after up Nebo, glorious or around LP faster than you.
Coilovers, sway bars, strut brace, decent tyres and learn how to use a clutch and steering wheel properly.
I don't want to hear any one else encouraging p platers to mod their cars in an illegal fashion. Yes, a 30 in a 33 is illegal. The motor wasn't an option and hence would require a blue plate.
Time and time again, the guys who've done it have said that it's not a great idea and have outlined the reasons why. If this doesn't suffice, contact someone else via pm. Colin had a pretty decent 32 and his advice is valid. If you want to play with the big boys, listen to the advice try give. If not, you will be a statistic and create more grief for the community as a whole.
This is a public forum and if you guys don't sort out your act, this page will be closed.
  • Like 1
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
