Mugabetown - Whoretownin' At It's Worst.
finished work at 1030 and ive spent the whole day "nostalgia gaming" my way through my child hood.
mario kart
mario 64
goldeneye
age of empires 2
counterstrike 1.5
bf 1942
command and conquer red alert 2
and generals zero hour...
so much win
  • Like 1
mario kart
mario 64
goldeneye
age of empires 2
counterstrike 1.5
bf 1942
so much win
I HATE U right now.
All of them ^ games above rocked my youths too
I went to TAFE at 7:30, the TAFE teacher said another sexist remark to my friend and I, went to my friends house and moved all her stuff out and into her new house, and then I'm buying a new bed frame :) my roomies so clean its like a I just moved in. Now to try and get zac to help.... :P haha
I HATE U right now.
ants ants ants.... how the tables have turned........... before i was envious of your tomei...
but now it appears i have the upper hand ... :) muhahhaha
in other news
was on a health kick and not drinking... then a xxxx and chips appeared :/
Edited by ibrox90
in other news
lol......them beers will tend to do that to ya
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
