Mugabetown - Whoretownin' At It's Worst.
Hai Scott, long time no see
Not all piping and not sure how to tell if it could be a problem or not unless it's a obvious split :/
even a small split will,throw out the air flow ratio and will make it run like crap
yeah do it. so hard to tell what could be wrong with it + im no mech so cant really provide any details technically wise
have you checked all your piping?
doubt it is piping (assuming noise happened when sitting idle at lights as he says)
Sceptical mike is sceptical
You're as young as you feel... And some days I'm sure we both feel 102 lol
What's crackin bro?
lol.....yeah spot on man.
Not much gonna punch some work out today which will be good.
Getting organized for our trip in Dec so getting excited.
How bout u? What's happening at your end of Gatton?
Not to much man, been a slow week at the bakery so haven't been doing a great deal. Have my cousins 18th on Saturday (the ford driver from the last happy laps) so I'm keen for that
i hate it when days are slow but I'm case they just breeze passed
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
