Mugabetown - Whoretownin' At It's Worst.
no man I don't. Cuz I live on the GC and not western Brisvegas
R I c. I miss mt nebo :( havent even really had a good fang around tambo either since I have moved close (2years) lol
yeah Mt Tambo is a nice drive but is heavily monitored theses days and wayyyy to many accidents which does not help :(
seriously it was sitting at lights when it happen didn't even boost it cause car was still cold.... so from that video you would look for a split ic piping ect?
Sounds very air leaky to me. After looking for air leaks unplug each coil pack. If the idle doesn't change you have found your problem cylinder. Did you say you unplugged the afm and it made no difference? I have had a failed afm and failed wiring to my afm cause issues similar to yours. My money is still on air leak though.
  • Like 1
How hard is a slappa RB30 ?
I now have a metal on metal ticking sound :angry:
I'm thinking I have lost 1 or maybe 2 cylinders, comp test next.
While pulling out the coil packs when running made the car want to stall on all, some didn't change much when plugging back in but did make a change..
PowerFC install stops the car hunting but as the car warmed up and idled dropped it wanted to stall causing it to hunt.
Anyone got a engine crane?
Yeah unplugged AFM then started car on stock ECU ran the same harder to start but did run
PowerFC installed to rules out ecu. Am unplugged wouldn't run. AFM installed it runs but missing..
Did the spray carbie cleaner around hoses and intake gasket.. no notable change..
Who can recommend a Mechanic Southside close to beenleigh ? If only ERD was open still.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
