Mugabetown - Whoretownin' At It's Worst.
have you PM'd 5tiv or Cadmoon or Zeke...?
OH MY GOSH!!!
Besties?
Yep - Pm'd two of them and one other in the past.
Unbelievable! still nothing?
I will look into this for you Tim, as at the bear minimum you should have received some paperwork by now.
Unbelievable and incredibly annoying
Anyone know how to stop the AAC valve from leaking?
It's leaking from the yellow plastic end
maybe some loctite Ed?
If the valve is leaking better off getting a replacement one IMO
Other Side of the vale is a plastic bung? It's leaking from that and haven't found any guide that show how to replace it or fix that part :/
Cooler pipe was leaking and bov leaking around gasket bought supplies to fix them..
Picked up a fuel filter too
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
