Mugabetown - Whoretownin' At It's Worst.
well if u do.......make sure you hit a few for me as well ;)
And me, always loved smacking 7-8-9 irons, and when you hit that sweet sw shot and it just sits when it hits the green.... Sah nice
And then comes the dreaded short game :rant:
I thought you stopped posting, as your keyboard was clearly bigger than everyone else's. :) Balance is critical. If it was so simple, why didn't you make one up yourself???
PS: I am actually fully trade qualified (Ask Ants) and build RB engines myself in what little spare time I have outside law. My latest build is 390AWKW SAU member's engine. Have you even touched or used the Ross trigger system, or just posting that they suck for the sole purpose of trying to contradict me? :)
Notice I put smiley faces, therefore it's a friendly post. :)
I didn't make one my self because a monkey with a cnc machine can make a prefect trigger disc in minutes. I don't give a f**k if you are qualified in every trade ever and made a 9000kw rb in your kitchen, you are wrong. There is nothing difficult about a crank trigger no matter which way you slice it, any machine shop in the country can produce the required disc. I have touched a Ross kit. Then used it to think of something else that does the same job for 1/4 of the price. At no point did I say the Ross kit is shit. It isn't, their price however is completely unjustifiable for the simplicity of the gear they supply.
I got my information on how to get the set up done simply and cheaply by a guy called Alan Heaply who also knows a thing or two about RBs. Probably even trade qualified but I would have to verify that with Ants.
CAN WE ALL PLEASE PUT OUR EGOTESTICAL BEHAVIOUR TO ONE SIDE!!!
IS THE ROSS CRANK TRIGGER KIT DURABLE AND RELIABLE – YES
IS IT EXPENSIVE? – WE ALL AGREE THAT IT IS
ARE THERE ALTERNATIVE SOLUTIONS AND CHEAPER CRANK TRIGGER KITS AVAILABLE – YES
I AM NOT VERIFYING ANYTHING EXCEPT FOR THE LACK OF RESPECT PEOPLE HAVE FOR ONE ANOTHER SOMETIMES
NOW, ENOUGH OF THIS HIGH SCHOOL BEHAVIOUR AND LETS BE SINCERE TO ONE ANOTHER AND HELP EACH OTHER OUT INSTEAD MATURELY
do you need a hug ants?
In other news, Ashes have started and Australia has chosen to bat first.
Now, can Australia maintain their 25 years test winning streak at the Gabba? Or can England make this Australiá's 10th test loss in a row?
  • Like 1
I don't think we will lose, the test series over there was pretty close, and this time its here, and we have a better team.
IS THE ROSS CRANK TRIGGER KIT DURABLE AND RELIABLE YES
IS IT EXPENSIVE? WE ALL AGREE THAT IT IS
ARE THERE ALTERNATIVE SOLUTIONS AND CHEAPER CRANK TRIGGER KITS AVAILABLE YES
  • Like 1
Big man hugs all round
And I think we will lose again. Maybe not in Brisbane, but we will lose the series.
Stupid Poms.
Stupid Clarke.
Edited by MagicMikeZ32
Ross can eat a dick. The price of those kits is Bullshit. I got my gear from some local guys who were able to provide the trigger, hall sensor and mounting kit for less than 400 bucks.
Hmmm slight contradiction on the Ross front, but you seem like a pretty complicated guy lol
Here's the killer for your argument about how a simple monkey can make it... Nissan couldn't get it right - Feel free to verify with your best mate Richard Cranium :)
For anyone who is interested, I exclude you Bunta (because you're such a knowledgeable guy) - Have you ever tried to bend a pen? If you hold it midway... it doesn't work but if you lengthen it and support it at the quarter way mark then the pen bends/wobbles... now if you add a trigger wheel to the front of the crank to extend out the front what happens?????
That's the best you got... is the guy clever enough to hold a law degree too - again ask yourself :)
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
