Mugabetown - Whoretownin' At It's Worst.
About to service the gtr with nothi g morw than a 25 dollar socket set... desperate times ... prepare for some mcgyver like shit.. not joking I dont even have a screw driver
mate......next time come around my place and you can service GTR there
YAY Car is alive for now, drives fine on old CAS but seems a little off when boosting so will keep that to a minimum till repalcement CAS or new one. (please santa )
Plugs changed
Oil/filter changed
Fuel filter changed
multiple air leaks fixed
aac cleaned
looks like ill be attending the Charity Cruise again :D
  • Like 1
Rule 1 don't sell your tools
Rule 2 keep at least one toy ( be that motor bike/car/race car
THIS
currently thinking about selling the skyline for a Motorbike but then i'll miss you guys
Plugs changed
Oil/filter changed
Fuel filter changed
aac cleaned
Good on ya mate.
Really happy you can be driving it again without those previous issues.
Servicing done... all good I think sheared one bolt . :-/ and may have poured 200ml of oil before I realised that the sp plug wasnt in but ok really
for those that are interested
i used 1x 2nd hand socket set from cash converters $25
1x Ka bar combat knife $ had for years
2 x empty 2 lt coke bottles $0
1x 1.25 empty coke bottle cut in half $0(half for oil half for a funnel )
1x ikea flat pack allen key $0
2x XXXX gold
penrite oil $70
new filter $24
thats a gtr serviced for $120
Edited by ibrox90
  • Like 1
So anyone knoq where I can get a coil pack rail bolt from ???
are you talking about the little bolt that holds the coil back to the metal frame or the big bolts that hold the coil pack metal frame to the engine head?
I have got the coil pack bolts from supercheap before
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
