I take it that the knock retard is from bearings tapping a little tune?
Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head
The hose and metal pipe had perished these are the best pics I took of it at the time
