Mugabetown - Whoretownin' At It's Worst.
Wow for my a sleep in is usually two hours . so 7am.... last two nights ive got a total of 28 hours sleep...
Also I cant help but notice that were all on here alot... "talking smack and giving sass" seems all very new internet agey to me.. which im all for buuuuuut.
why dont we have a BBQ on a Saturday arvo or a Sunday sesh somewhere????
Edited by ibrox90
wouldlove too mate.
But next weekend is my last before I go O/s so I will have to do it next year after I return.
I'm sure some other guys will be keen
New car yesterday. Traded Madge the mazda 6 in for an outlander.
havent taken delivery yet, it better be undercover!
Edited by MagicMikeZ32
Fuark this body line BS
Its not the bowlers fault the poms have bought along 11 players that can't play a short ball. They loved beating up in us on dead tracks that they are used to. Welcome to Australia bitches :D
  • Like 1
Adelaide will be dry - like the people.
MCG & SCG will be the interesting ones.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
