Mugabetown - Whoretownin' At It's Worst.
3-4k no motor n box. Up to 6-7k with a broken motor. Thats what id pay anyway. Money to be made if you have the space, time and motivation to part them out
So house has finally settled so my bank is forever negative balance haha. Will be good getting the first rent payment in though.
Not getting another gtr now though, might get a bike instead but most likely going to just spend the money on a holiday next year, going to need it after this job lol
Congratulations mate! House party?
Stuff that, too much to clean up. Well Cara would clean up, but I'd have to listen to it.
Might hold a tech day at my place sometime in the new year. Have to check the SAU calender.
If you were a member, you could see the calendar... :whistling:
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
