Mugabetown - Whoretownin' At It's Worst.
Torque is something Im not to familiar with in regards to what sized engines should be creating what amount of torque. Understand what it is and how it works just not average each engine makes.
Fair enough. It's pretty confusing and takes a lot of calculation to get the actual engine figure. I am guessing yours works out at 550 to 600nm at the engine.
12 to 16 cars for a track day... Ain't gunna happen in NSW unless your guys are prepared for $450 just to run Wakefield... If going to texi, they don't go for times anymore, they just do burnouts. Its why anyone quick either moved to Qld or stopped going to texi...
Sounds like I'd enjoy this "texi" thing
Dont rb25's put out around 700nm of torque? wouldnt a 30 make more?
It cant be 2400Nm of torque...
Even at 2000rpm, that's 500kws... Which is more then your peak power.
If youre making 380kw at around 6500rpm, at that point youre making 558nm of torque...
let's do the calculation. What size wheels and tyres do you run? We need the radius from hub to the tyre. And what diff is in there?
I found this post in the RB30 thread. Very similar setup to mine
Haltech R34 GTT Pro Plugin
Spool 3.4
260 10.8 Procams
6boost & progate 50mm
Precision 6466 1.0AR TS
20psi on Caltex eflex
Martin you just brought me lulz.... *golf clap*
Also you bastard why u no come for beer on Sunday every one was like "where is Martin" and then mike was like "f**k Martin I hate him and his gay car" ... True story
</3 Mike :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
