Mugabetown - Whoretownin' At It's Worst.
Torque is something Im not to familiar with in regards to what sized engines should be creating what amount of torque. Understand what it is and how it works just not average each engine makes.
Fair enough. It's pretty confusing and takes a lot of calculation to get the actual engine figure. I am guessing yours works out at 550 to 600nm at the engine.
12 to 16 cars for a track day... Ain't gunna happen in NSW unless your guys are prepared for $450 just to run Wakefield... If going to texi, they don't go for times anymore, they just do burnouts. Its why anyone quick either moved to Qld or stopped going to texi...
Sounds like I'd enjoy this "texi" thing
Dont rb25's put out around 700nm of torque? wouldnt a 30 make more?
It cant be 2400Nm of torque...
Even at 2000rpm, that's 500kws... Which is more then your peak power.
If youre making 380kw at around 6500rpm, at that point youre making 558nm of torque...
let's do the calculation. What size wheels and tyres do you run? We need the radius from hub to the tyre. And what diff is in there?
I found this post in the RB30 thread. Very similar setup to mine
Haltech R34 GTT Pro Plugin
Spool 3.4
260 10.8 Procams
6boost & progate 50mm
Precision 6466 1.0AR TS
20psi on Caltex eflex
Martin you just brought me lulz.... *golf clap*
Also you bastard why u no come for beer on Sunday every one was like "where is Martin" and then mike was like "f**k Martin I hate him and his gay car" ... True story
</3 Mike :(
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
