Mugabetown - Whoretownin' At It's Worst.
Torque is something Im not to familiar with in regards to what sized engines should be creating what amount of torque. Understand what it is and how it works just not average each engine makes.
Fair enough. It's pretty confusing and takes a lot of calculation to get the actual engine figure. I am guessing yours works out at 550 to 600nm at the engine.
12 to 16 cars for a track day... Ain't gunna happen in NSW unless your guys are prepared for $450 just to run Wakefield... If going to texi, they don't go for times anymore, they just do burnouts. Its why anyone quick either moved to Qld or stopped going to texi...
Sounds like I'd enjoy this "texi" thing
Dont rb25's put out around 700nm of torque? wouldnt a 30 make more?
It cant be 2400Nm of torque...
Even at 2000rpm, that's 500kws... Which is more then your peak power.
If youre making 380kw at around 6500rpm, at that point youre making 558nm of torque...
let's do the calculation. What size wheels and tyres do you run? We need the radius from hub to the tyre. And what diff is in there?
I found this post in the RB30 thread. Very similar setup to mine
Haltech R34 GTT Pro Plugin
Spool 3.4
260 10.8 Procams
6boost & progate 50mm
Precision 6466 1.0AR TS
20psi on Caltex eflex
Martin you just brought me lulz.... *golf clap*
Also you bastard why u no come for beer on Sunday every one was like "where is Martin" and then mike was like "f**k Martin I hate him and his gay car" ... True story
</3 Mike :(
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
