Mugabetown - Whoretownin' At It's Worst.
You should get away from all that and enjoy serenity with your family. GTA will always be there. The opportunity to watch your girls grow up won't. :)
meh.......right now GT6 would be very handy
Good morning / afternoon all
Ohh, Dell is going to start selling 3840 x 2160 resolution monitors this month. Might pick up the 28" one sometime next year. Pity i'll need to build a new computer to run it.
i have 2 of the dell 2560x1440 27" screens. do rate.
im doing exactly that :)
