Mugabetown - Whoretownin' At It's Worst.
Most people Ive dealt with to get a RWC are quite relaxed when it comes to getting a car you already own looked over to be registered by for you. Its normally ones where you're going to sell the car they get a bit pedantic
I'll take that as a no then
removing it is easy, its only a couple of bolts.
just make sure you mark it so you can get the timing right when you put it back on.
mark it where though .... thus my worry
you mark where one of the bolts is, you can mark two if you want.
should be 3 bolts that hold it on/allow adjustment, when putting it back on be sure you check the end of the cam and the CAS to make sure you dont damage the cas drive when reinstalling it, it should not take much effort to slide it back into the cam if its lined up properly.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
