Mugabetown - Whoretownin' At It's Worst.
How are you ants. Stinking hot day in Brisbane today. Top of 41
Hottest January Day since the 40's apparently
Im good mate.
40deg!!!
So glad I'm not in Oz to experience that silly heat!
I hate the summer heat full stop!
nah mate all target jsut me getting pulled over.
I reckon on was a tip off casue he pulled me and breathoed me 3 times and drug tested me twice.
did my breatho training not that long ago and really one is enough. i think they thought i was someone else.
other 2 were license checks and one was a defect, breatho and license.
actually stood at the front of the car for 30 mins talking to the cop. He was a top bloke.
just remember guys. cops are taught to apply discretion and the "attitude test" so don't get snarky until you're sure of the outcome.
wrong place at the wrong time........it happens
Agree. Just be sensible with the boys in blue
I do believe thats what its called.
Actually watched a pretty cool Matsuri video the other day. Wouldnt mind attending one, spectating only though as i cant drift lol
Have been the last two years and jumped in a few different cars, this year we'll be heading out in a super f**kin widebody s13 with an ls1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
