Mugabetown - Whoretownin' At It's Worst.
Morning everyone.
Bunta, thanks for recommending battery doctor. My phone actually lasts during work now although it still had to be plugged up. Apparently it doesn't like charging over USB...
No worries.
Howdy all Ecu dropped at store for modifications for rb25 should be 125 and mines afm plug is ordered going to be taking that to an auto elecy to do
All that is left now is some ball joints, shocks, front mount, highflow, sub frame and diff bushes, clutch and brakes
Already have a stockpile of parts at home and in the car.
Just over 2g left to spend and I'm done :D
Then spending all the kesh on the 25/30!
what power capable high flow?
you will likely need a bigger turbo if you go the 3L, they are very much a GT30 sized unit minimum deal.
This. If your putting a new turbo on your 25 only to latter add it to your 25/30. I reckon it needs to be a GT35 or bigger. As Tits said GT30's are a minimum but to get a decent number from it you should be looking at a 35 or equivalent
Howdy all Ecu dropped at store for modifications for rb25 should be 125 and mines afm plug is ordered going to be taking that to an auto elecy to doAll that is left now is some ball joints, shocks, front mount, highflow, sub frame and diff bushes, clutch and brakesAlready have a stockpile of parts at home and in the car.Just over 2g left to spend and I'm done :DThen spending all the kesh on the 25/30!
sounds exciting Zac ;)
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
