Mugabetown - Whoretownin' At It's Worst.
Bloody oath it was. The timing of getting a new air con for the bedroom last week was perfect. The dehumidify mode got a good work out.
yep. We had ours running and then turned off around 9:30pm. Twas a mistake
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
