Mugabetown - Whoretownin' At It's Worst.
So.......for once that I want to play for just 10min on PS3 (GT5) and I made it clear to my wife 'just ten minutes' (I rarely play it)
I don't even get five and my older daughter is deliberately crawling all over me and my wife tells me 'I don't want to have the PS3 there......move it back in the computer room'
FOR f**kS SAKE!!!!!! I WAS JUST ASKING
FOR TEN MINUTES..........JUST TEN!!!!!!
lol
I bought GT6 on Friday. Installed friday night. Said to the wife I am going to play the new game for a bit last night. No worries she says. I got 1x2 lap race in before she hands me the phone. Bloody mum rings. Spend next 25mins on fone to her. Then dinner is ready.
Awwwwh FAIL
lol
Awwwwh FAIL
yeah man.......know that feeling all too well.
All this of GT6 has got me thinking..........
I better get it ;)
Store the PS3 at work and play in the boardroom at lunchtime
Saw MagicMike posted in Whoretown, knew it would be about brakes...
You guys are getting too predictable lol
ORELY?????????
BOOM!!!!!!!!!!!!!
YOU DIDN'T PREDICT THIS NOW DID YOU!
lol
Awwwwh FAIL
Just wait until Cara gets clucky bro. Then it's all over.
Tyler is heaps stoked with his first day at school. Shall see what he says tonight.
car looks blue.........I'm thinking you should vinyl the car blueish like
I'd love to do it black with hot pink glitter, and throw on a set of Meisters with the centers sprayed the same colour and chrome lips
Like it looks black but when light hits it u can see the colour
Who wants to sell me their tv hella cheap ;)
All it needs is hdmi input and 1080p compatible size I don't care
You don't have a HD tv? WTF?
They are so cheap these days, just buy new
Nick, This is Sau not Boostcruising
Mine blew up last week in a storm :(
And am saving money for other shit
Because racecar
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
