Mugabetown - Whoretownin' At It's Worst.
Hope so
So do I! Great looking house/property you have there Mike and very friendly k9's!!
Thanks mate :)
haha yeah they are quality guard dogs :D They hate black people, Tony is scared lol
Morning Mr Ants.
Thanks for joining that group. Now go post up something in the welcome thread :P Need you to get the ball rolling because Accountant :P
Ok. I will have a look at it when I can mate.
They may have lick/sniffed me to death that's about it...
Sounds just like them! Unless you are walking past out the front... Or unless you are a mailman hahaha
How come ants?
Had a customer booked in tomorrow drop there car off in the morning ad ask to have it done by 11 because they are busy tomorrow..... And we had 3 cars in for the day already :/
FARKING BULLSH!7
How come ants?
FARKING BULLSH!7
just breakdown in communication mate which shits to know end theses days and makes me feel like a dickhead.......hence shit day.
Did you tell the customer you already have other customers car already booked in?
Plus what really makes their car a priority over the existing cars booked in????
That's every day here ants.
well Pete if that's the case you have some pretty unique tolerance levels because that shit rarely happens to me and when it does I just want to tear a new one in the person(s) that I feel are responsible.
In my industry, such breakdowns cause frustration and friction that could have been avoided. More importantly it's costs real money as time is wasted / not recoverable which means my peers aren't impressed and neither am I. So
GRRRRRRRRRrrrrrrrrr
Yes we told them
And there like but I'm leaving for Sydney tomorrow....
We are like..... Da fuq bra. Go away you crazy old batty lady
Needles to say we did it and charged her out rush labour charge and she was like ok sure
Hahahah thanks for the 149 an hour
Thanks mate.
Need to start creating some traction there. Got a few interesting things on the go. You would probably be interested.... Call me when you have a chance.
Know the feeling bro. Know the feeling....
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
