Mugabetown - Whoretownin' At It's Worst.
straight off the ATO website nice one Tony. This ^ is also why this option may not be a viable one..........as the level of audit risk is significant and although would not benefit a tax advantage it from it, it would create unrecoverable time charged............for something the client would not understand.
Nope. From Deloitte. As if trust the ATO. :-P
I am aware of the power that 101 Motorsport car makes lol...
No traction isnt joyous when you are trying to keep it.... Mind you no traction does get the bitches I've heard
when you can do 400m power skids without ever touching the brakes, the bitches be moist.
Happy Valentine's Day to all the sexy beasts out there....
All the not so sexy beasts can suck a fat one.
The good old Hallmark holiday... lol
Aimee & I have been dating for 5-6 years, still never given each other a single gift for Valentines Day. This year aint going to change
Yeah... I got Chants something small. Tyler and I bought her a charm bracelet for Xmas. So buying a present for any occasion now is easy as! :-P
alright mate. Just got a valentines day from my wife...........she doesn't know it but I have one for her two with chocolates to suit ;)
And you sir?
Body chocolate.............
I used to buy my GF jewellery, however she hardly ever wears any so I gave up
Ha, I aint buying a thing lol...
Buy a single rose, a Rembrandts cd and body choclate... The rose may die, and you may run out of body choclate but The Rembrandts will always "be there for you"......
http://m.youtube.com/watch?v=nzQWmAwNNCw
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
