Mugabetown - Whoretownin' At It's Worst.
Yes a special tool was cobbled together out of 3 x 1/4" extensions and a knuckle joint etc etc to narrowly avoid everything in the bay and latch onto the 14mm bolt, smashed it out in minutes.
Nope not in comp with Labdirect, so busy with my 'real' job that I don't have time to look at anything else at the moment :(
Today is a good day for a drive, methinks
Pete I would say radiator out, fan and clutch off, belts off, covers off, get it on top dead center, crack all the cam gear bolts before you losen the tensioner on the belt, mark edge of belt and gears with white out or paint pen, losten tensioner, slip belt off, carefully remove gears without turning cams, transfer marks from old gears to new ones, put back togeather the belt, turn the engine over by the crank bolt about 6-8 revolutions and then line the timing marks up again off the pulleys and block( the belt will be in a different spot)
If they all line up back togeather undo the tensioner and then retighten so it is seated right
Once tight, tighten cam pulley bolts and put it back togeather
While your in there I would recommend getting a timing belt kit, do the pulley's and seals same time
And also while you you are that far in you should probably do water pump
Pm me if you want and I can give you a full rundown but more descriptive
or just give it to Zac to do :)
Yeah but that costs lots of cash moneys
I can get a quote for Pete and let him know on Monday
Also Zac.........attachicon.gifImageUploadedBySAU Community1392450026.288363.jpgclutch fan and cooling fan is back in its place all shiny and stuff ;)
This makes Zac happy :)
Glad I could help
Yeah, i've been digging through guides, process itself is pretty straight forward. Thanks for the tip of smashing off the cam gear belts before removing the tensioner, hadn't thought of that one.
Timing belt and pulley's have been done recently, unless the tensioner/water pump etc is obviously stuffed i probably won't bother replacing them, either way once i tear it down i can make a decision and get the parts before i put it back together again.
Then.. fuel pump, injectors and AFM.
Then getting the car to the workshop. I'm figuring flatbed may be the best bet, anyone know a good towing mob?
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
