Mugabetown - Whoretownin' At It's Worst.
Yeah, will see how i get on.
Back out to site Midday Wednesday, which could throw a spanner in the works if things go south, but we'll see...
too hot to drive turbo car me thinks
Exactly what i thought, that's why i'm going now.
My parents went for a drive to Tamborine in their datsun fairlady. Got very very hot under the black vinyl roof...
Well that was crap. Whole bunch of supras and really old jap cars.... Nice but didn't see any skylines...
What supra's?
Also, there was a 2 door 32 and a 240K there, and my car parked out on the road!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
