Mugabetown - Whoretownin' At It's Worst.
Located in Wishart Mike.
Fuel injectors haven't arrived, and i'm about to go back to site, so the 6th of march is The day that they and the AFM's are going in, I get back on the 5th and car is booked in on the 7th. Shouldn't be to hard to knock over in the day though. The software seems fine in Trial mode, it isn't cut down at all, just limited to 10 minutes per use. If I could borrow a cord though, that'd save 100 bucks...
Latest musing on my car related shenanigans:
  • Buy consult cable, (this would work, right?)
  • install free Nistune trial software,
  • adjust injector CC and AFM to match,
  • drive car to EFI
  • Profit
Sound like a plan?
That's all I did when I did mine. Just don't go nuts on the way there before the tune.
I'm astonished at the level of risk your taking just to save a few hundred dollars.
Sean will have to recheck EVERYTHING you will have done and in the event something is not right he will have to fix it.
Yes he can easy install AFM and especially injectors, including fuel pump, ECU etc......
Didn't know that, have not been there apart from dyno day (where i was sick as a dog) since ERD closed down.
As far as the ECU goes, i'm talking about changing injector sizes and AFM's. Its a case of putting old and new CC and it scales the map, and selecting Z32 from a drop down list. Not actually messing with any of the ignition/fuel maps etc.
its all at your discretion Pete. All I know is that it's a long way for you to drive the GTR to EFI and if something goes wrong in between..........well it's just a long way
If the nistune scales the map for you, you should not have any problem
I think a long drive is overdue then. Then retune and bring to next happy laps :-)
i agree but bits of car are being reprinted FTM.......plus I'm very busy at work so limited time.
Yes, a full tune with E85 is on the cards ;)
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
