Mugabetown - Whoretownin' At It's Worst.
hey everyone! what's been happening?
I'm no longer a skyline owner but still have something Jap, i Bought a brand new Yamaha XJ6N. Its much better than the car for commuting to work.
I will have a post up soon with some of the left over parts you all might be interested in buying.
No time for beer!
have to finish work at 6, hit the gym, have a shower, have dinner and then it'll be to close to my bed time to bother!
beer is not good for you Pete but good for me :P
f**ked my back installing brake switch stopper rubbers In my bluebird this arvo. 2hrs is too long to be upside down with a reverse kink in your back
get Bec to set you straight!
Had a piece or rust left in my eye from last week
They got it out and I feel the exact same as last week
Locked in my room all weekend..... Again..... In the dark....
Woah everyone is in the wars
I'm not getting rid of mine any time soon
I still havnt even been able to power mod yet
glad they got that last bit out of ya mate.
Not selling mine either ;)
I had mine 7 years and it just turned into a expensive daily drive to work with no extra money to spend on it the car was going backwards in quality.
Going back to my SSS U13 for my daily until I get my Ps for my bike.
