Mugabetown - Whoretownin' At It's Worst.
When I say responsibility for the management of the team, you know what I mean and where I'm coming from.... It's our rep on the line. Recruiters are already treated as scum, don't need more negative attention./
Im not disagreeing with you just telling you that for every action you undertake there are or will be reactional consequences. That's all.
Yup. And that's why I haven't done much as yet.
I basically told our ex-MD that if she doesn't get sorted, I will sort it out in 5 weeks. Why 5 weeks? 1 for me to call/catch up with a few people I know. The other four for my resignation period... He got the message loud and clear
Hmmm project car just don't have anywhere to hide it from the wife
http://www.gumtree.com.au/s-ad/slacks-creek/cars-vans-utes/1993-nissan-skyline-r32-gtr/1039822815
Pretty cheap, drop 7ish K into the engine and you are away!
So... almost all iron we mine in the world now was formed by bacteria in shallow water releasing air and causing iron to dissolve out and settle on the seabed very very slowly over millions and millions of years.
Same sort of deal for oil and coal.
I feel insignificant Yet very lucky.
yes mate, that stuff was learned at middle school
Quarter miles are boring anyway.
Not in a 50+ year old car :P
Burn dinosaurs BURN!
Sup
Carnt
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
