Mugabetown - Whoretownin' At It's Worst.
exy on fuel, insurance more expensive, chances of having an accident also greater, and probability of been victimized by the local authorities.......imminent
Common sense is strong with this one :-)
Only cause the prestige boys chicken out because they're mad we can spend what the would spend just on their car on buying ours and modding it and pretty tieing with them
I highly doubt they are the slightest bit mad.
Ugh, don't really want rain for my rnr again
You're young n fit..............you're RnR should be working on the GTR irrespective if there is rain, hail, cyclones............shit whatever mother nature throws at you.
agreed, I'd have a super if I could afford it.
then mod it :P
I'd love to hack one up, like buy one with a blown motor gearbox electrics etc and drop drop in a turboed ls setup with a transaxle. All the go none of the repair bill when you throw a rod
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
