Mugabetown - Whoretownin' At It's Worst.
How are things on your end? Was reading what you were saying about the systems being down and thought, "who the hell is playing golf in this weather?!"
Quiet with all this rain.
The big frustrating thing about our sytsem is that it runs an electronic tee sheet & our POS system. So if its down you have no idea how busy its going to be, who is playing & what rate they are meant to pay. As we start at 5:30am there is generally no tech support that early either so its frustrating at times
Move to a provider who can provide after/before hours tech support?
Unfortunately the providers we have are actually the biggest in the business, whilst they may not offer the best tech support may not be the best.. There is extra revenue streams they offer that other systems dont etc.
Necessary compromise it appears...
So, I bought a hard pipe kit so I could fit in my z32 afms. And it has no bung for the bov return pipe on the rear turbo, should I just block that line off and run the bov only to the front one?
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
