Mugabetown - Whoretownin' At It's Worst.
not even ducks......................because they quack a lot and you never know what they are truly saying.
Oh I know what they're saying they are schemeing planning little bastards plotting to manipulate the current government into giving them tax cuts
I care so little for work I am considering quitting. This current lot of complainants are killing me. I got offered a sweet job, with no public contact required...but it is based in Ipswich.
Wouldnt be that bad, the motorway is close and youd be against traffic, youd need a daily though
I used to drive my blue 32 to Gatton everyday the GTR could handle ipswich. Though I could take the mazda and Anna could take the GTR to her work which is only about a 10k trip
I can't remember it, did you live on crest view avenue?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
