Mugabetown - Whoretownin' At It's Worst.
That's because I don't line up against anyone. Plus lakeside = corners
but but but why not? I reckon it would be a good match between you too.......got the solution.........SAU drag day ;)
Done drag day a few years ago. Best I did was a 14.7. I babied the car heaps though
yeah, 18. Not low enough apparently, blew the hose on the imtercooler off just then, I can't get it back on... So waiting for a tow.
f**k.
Yep know that feeling all too well Pete.
These cars with standard IC are renowned for blowing off when increasing boost pressure.
I now have hard piping and serious clamps on board ;)
I tell ya what Chris il let you drive mine if you let me drive yours. Il guarantee you a high 12sec pass :)
It won't be a time attack Bodo. Me thinks you have skyline fever
Yeah it's happy laps, I won't be going anywhere near fast enough to have issues, I just want to go for a drive with the ant eater!
  • Like 1
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
