Mugabetown - Whoretownin' At It's Worst.
That's because I don't line up against anyone. Plus lakeside = corners
but but but why not? I reckon it would be a good match between you too.......got the solution.........SAU drag day ;)
Done drag day a few years ago. Best I did was a 14.7. I babied the car heaps though
yeah, 18. Not low enough apparently, blew the hose on the imtercooler off just then, I can't get it back on... So waiting for a tow.
f**k.
Yep know that feeling all too well Pete.
These cars with standard IC are renowned for blowing off when increasing boost pressure.
I now have hard piping and serious clamps on board ;)
I tell ya what Chris il let you drive mine if you let me drive yours. Il guarantee you a high 12sec pass :)
It won't be a time attack Bodo. Me thinks you have skyline fever
Yeah it's happy laps, I won't be going anywhere near fast enough to have issues, I just want to go for a drive with the ant eater!
  • Like 1
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
