Mugabetown - Whoretownin' At It's Worst.
Looking good Scottie
my original thought was to try and keep the stealth look about it.
But then i thought the sound of the car and the big as F*#k drag wing on the rear kind of gives it away lol
Are you coming to happy laps Ants? even if its just spectating and racking up KM's on the Anteater but no tracking
i will see how I go mate. Still got a bit of resto / paint work to do on car before it runs again.
Plus suspension and brakes need some Zac attention :)
Nice one. Mr Scott, how goes the brakes?
Quite good actually .Well the car doesnt get driven all that much but when it went to QR they handled really well. However my mechanic seems to think I put them on upside down. Either way they still seem to work fine
Ants, loving the CF detail in the map pockets. Very nice!
I went through a stage a CF wrapping almost everything. It gets so addictive
How did you manage to put them on the wrong good way around? Pics!
well Richo reckons the bleeder should be on the top and not the bottom like Ive done. SO the Left Caliper should actually be on the right rotor and vise-versa. If you know what I mean...
#@MagicMikeZ32 might be able to shed some light on this?
I reckon he is right
He races cars every weekend so I think he is right as well. HE reckons that there "may" be some air left in them right at the top. So potentionally they will work even better. however the effort of taking them off and on again really doesn't tickle my fancy
I agree. They work really really well once warm now. Hard to think they could be even better!
Also a put a fresh set of plugs in yesterday so my misfiring issue is resolved short term. New coil project in the works though
They won't stop you faster or anything but it will give you a better pedal feel which is always handy.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
