Mugabetown - Whoretownin' At It's Worst.
Looking good Scottie
my original thought was to try and keep the stealth look about it.
But then i thought the sound of the car and the big as F*#k drag wing on the rear kind of gives it away lol
Are you coming to happy laps Ants? even if its just spectating and racking up KM's on the Anteater but no tracking
i will see how I go mate. Still got a bit of resto / paint work to do on car before it runs again.
Plus suspension and brakes need some Zac attention :)
Nice one. Mr Scott, how goes the brakes?
Quite good actually .Well the car doesnt get driven all that much but when it went to QR they handled really well. However my mechanic seems to think I put them on upside down. Either way they still seem to work fine
Ants, loving the CF detail in the map pockets. Very nice!
I went through a stage a CF wrapping almost everything. It gets so addictive
How did you manage to put them on the wrong good way around? Pics!
well Richo reckons the bleeder should be on the top and not the bottom like Ive done. SO the Left Caliper should actually be on the right rotor and vise-versa. If you know what I mean...
#@MagicMikeZ32 might be able to shed some light on this?
I reckon he is right
He races cars every weekend so I think he is right as well. HE reckons that there "may" be some air left in them right at the top. So potentionally they will work even better. however the effort of taking them off and on again really doesn't tickle my fancy
I agree. They work really really well once warm now. Hard to think they could be even better!
Also a put a fresh set of plugs in yesterday so my misfiring issue is resolved short term. New coil project in the works though
They won't stop you faster or anything but it will give you a better pedal feel which is always handy.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
