Mugabetown - Whoretownin' At It's Worst.
thats quite the collection Ants, very impressive!
thanks mate. but really thats nothing. I have my HP (Highland Park collection) which is amazing and I have bottles of scotch stashed in most cupboards in the house.
I will post a pic of the HP collections soon.
well its Macallan mate. She's like the Nike of single malts its very good stuff but I find the price hard to justify.
Its why in fact Macallan went down the path of introducing the fine oak range because production costs are lower using american oak barrels (bourbon) rather than sherry oak barrels, however even their 18yo was like $189 IIRC.
My thoughts are as follows:
Fine oak - cheaper than Sherry oak and is very fruity, makes your mouth water / dry and then releases beautiful flavors like vanilla, raisins and fudge
Sherry oak - very exy but my favorite but caramel galore. Could really go without that artificial coloring IMO but the tastes - at first its very spicy, but after you have drank a dram you get the following flavours, burnt cookie / creme caramel, spices like cardamin, orange peel and a hint of wooden smoke - truly amazing mate.
you can make your own recommendation but I think you know what to go for now.
Thanks mate. Definitely know now what to get now. Johnnie Red. :P
I haven't had scotch for ages, I am in my beer phase at the moment, I go on runs where i get the same thing over and over, though I am sure with winter closing in spirits might be back on the menu
same. I take my beer and jagermeister on hot days (put the jager in the freezer)
in winter I crack the whisky open ;)
I have a new favourite whiskey in the cheap range. .. and it's bourbon :0 never thought I would say that.
hmmmmmmmmmm...........yeah not a fan of bourbon eh..........but can be good mixed I guess.
I am not really into it either! But this one is nice, mixed of course! Its Blantons Bourbon, and it really shocked me.
may try one day. but first I have to finish what I already have.
Fair enough bro
If you wish to measure performane from happy laps knock yourself out! Your car is 1000 times faster at Happy Laps than mine, I think I am yet to use full throttle at one based on the fact in my view is neither the time or place.
once crank trigger and tune done and a bit of TLC to suspension the unicorn will be a weapon on track IMO
Woohoo I win :D
sweet, thanks! I plan on doing a flex set up at some point too,
Something i've thought a bit about, however in the end I realized that in 3 years I never took my car far enough that I wouldn't be in range of either caltex/united fuel at their current locations.
Assuming you could get around well enough off boost using one when tuned with the other, I could have theoretically done it all on E85, so in 6-12 months I think i'll just get E85 done on the nistune and not worry about the expensive of a flex setup.
If you have a decent ecu the only extra expense is a flex sensor and a few hours on a dyno
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
